Hello all!
I am new to the forum and have searched high and low for a solution but I can't seem to find one.
I built my first PC about 6 weeks ago but I'm having problems with test #7 on Memtest86. My PC passes the Windows Memory Diagnostic Tool and Memtest86+ but fails test #7 on Memtest86. Am I doing something wrong?
I am using the following:
AMD 1100T
ASRock 890GX Extreme4
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL7D-8GBRH (Timings set at 7-7-7-21 2T, 1.5v, all other timings are set to AUTO)
I am not overclocking anything.
I've run the test on both and then each stick by itself with the same results. Are my sticks bad? Is this cause enough to RMA?
Any help would be greatly appreciated. Thanks!
AMD 1100T
