Hi everyone,
It's my first message on this forum. Sorry for my English, it's not my mother tongue.
My question is quite simple : does anyone know whether the Noctua NH-C14 (the top-flow model, I'm not talking about the NH-D14!) with the two fans is compatible with the G.Skill RipjawsX modules?
I have already asked Noctua but they aren't totally sure about the compatibility. They think it's OK but, as I said, they aren't sure.
According to Noctua's website, the NH-C14 cooler has a 38mm clearance and according to some people on the Internet the RipjawsX modules are 40mm tall...
I wanna buy an Asus P8P67 Deluxe motherboard and an NZXT Phantom case. Do you think everything will fit with each other?
Thanks!
Thanks!
