Hi there im new to this forum so pls be patient with me
i got a question regarding this gskill product
F3-17000CL7D-4GBXHD
i need to setup all ram details in my bios manually since it doesnt support XMP proper, therefor i need all the other details to put in except for the CL settings i didnt manage to find any infos (7-10-7-27-2N was only thing i found).
CAS Latency
RAS to CAS Delay
RAS PRE Time
RAS ACT Time
DRAM Timing Mode
those settings i was able to get of course from the recommendation of the product
would any gskill staff member pls be so kind to give me all remaining settings so i can fix this proper? (settings for max. performance).
right now i am running on bios standard JEDEC settings except for the above mentioned settings.
thank you very much for your kind help.
F3-17000CL7D-4GBXHD
CAS Latency
RAS to CAS Delay
RAS PRE Time
RAS ACT Time
DRAM Timing Mode
