Hello, I need some help with what I am sure is setting to get my MB to work with some of your memory. My computer will not even post with all 4 sticks of this memory in stalled. What would you suggest so that I can get the last stick installed and run at the full 16 gig my MB will support?
Thanks for any help you can give.
1 x G.SKILL Ripjaws Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9Q-16GBRL
It will run with any 3 of them. My MB is a
1 x ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard
I can use all 4 of this memory fine.
1 x G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model F3-10666CL8D-4GBHK
Processor 1 x AMD Phenom II X4 945 Deneb 3.0GHz Socket AM3 95W Quad-Core
I am not overclocking
Bios is set to auto for the memory.
I run Win 7 Pro 64 bit
