Hello! I am building a computer and I have a few questions I like to ask. I have built about a dozen computers in the past but I have never over-clocked them. I would rather have a more stable system and give up a little speed. The computer would be for using Autodesk 3ds Max, Revit, and Photoshop. I am using the advice I found here on using the 24gb kit rather then 2x12gb kits
Motherboard: Gigabyte GA-X58A-UD3R (ver2.0)
Processor: I7-950
Video card: (Not decided on one yet)
1: Would Ripjaw 24GB DDR1333 (F3-10666CL9T2-24GBRL) be OK with the Gigabyte GA-X58A-UD3R (2.0)?
2: If the Ripjaws are OK should I let the motherboard auto set it or manually set the memory?
3: If I manually have to set the ram, what should I set it at?
I appreciate any advise you can give me, Thank you very much.
Processor: I7-950
