Has anyone had experience with using a full 24GB using two of the 12GB G.SKILL F3-10666CL9T-12GBRL Kits on the Sabertooth X58? I plan on a Gluftown processor (i7-970 or i7-980X), mostly for video editing, and no overclocking of anything. Stability and full use of the 24GB is my primary goal. Thanks.
Asus Sabertooth X58 Compatbility with 2 G.SKILL F3-10666CL9T-12GBRL Kits (24GB total)
Finally memory prices are coming down, so 24GB is affordable!
http://www.newegg.com/Product/Produc...66CL9T2-24GBRL
Thanks for the 24GB kit pointer. Assuming I get the 24GB kit (F3-10666CL9T2-24GBRL) to install into the Asus Sabertooth X58 motherboard, are there any special BIOS settings I will need to change to ensure that this memory is running at is optimal speed and that all of the memory is properly seen by the system? Again, my plan is to run an i7-970 or i7-980X Gulftown processor, and I have no plans to overclock anything. Thanks.
The set is tested to run together at the listed specs, am guessing though (just the fact that it's 24GB) might take a little tweaking , probably voltages. Will want the latest BIOS for the mobo, pref before you start.
