... for F3-10666CL9T-6GBNQ (DRAM bus and QPI), and where did you find this data? Thanks.
What are the maximum safe voltages ...
W/ GSkill sticks you are generally safe up to .1 over max advertised DRAM voltage, so with this set 1.7. QPI is more CPU driven, but again, in varying opinions, calls for no more of a difference of .5 between QPI and DRAM voltages, and Intel says no more than 1.65 for DRAM - all depends on where you look
Well, I bumped DRAM voltage from 1.5 to 1.56, ensuring QPI was <.5V different, and that seems to have done the trick. After 5 reboots or so over the last couple of days I've always gotten the 12GB I have installed. I never got the same quantity twice before, and rarely all 12GB. Thanks for the help.
spec is actually at I7-900 series processors datasheet also xeon datasheet and voltages are really weird as those are saying in english that max DDR3 voltage should remain 1.55v and QPI at 1.35v at absolute max. (Didn't find anything anywhere on Intel documentation about 1.65v)
weird thing on these memory manufacturer sites is that most of the RAM is 1866-2000Mhz what really there is and absolute max you will do with these specifications is around 1500Mhz as so called 'Uncore'/'QPI' voltage stops POSTing pretty near 3700Mhz at maximum voltages and RAM again barely makes it to 1500-1600Mhz with 1.55v."Sex is like freeware, shareware on weekends. When do we get to open source?" -TwL
