I just got the Ripjaws 4GB (2*2gb) DDR3 Model: F3-10666CL7D-4GBRH cas 7 7 7 21 to use them with a Gigabyte GA-ep43t-usb3, which comes with a 775 cpu slot
I already set the basic timings(7-7-7-21 @ 1.5V) in the BIOS, and they work fine, passed Memtest, nice....
I don't have any intentions of doing overclock neither to the timings nor to the stock memory bus(1333). I just want to run them with my Core 2 Duo e6320 with the FSB Overclocked from 266 to 333mhrz, and set the Mem ratio to 1:2...
Anyway, My questions are:
1) is it safe to set command rate to from 2 to 1? I'm asking this because I have read that only the "expensive models" can handle a CR of 1 and work stable...and that is better running a CR=1 on non double sided Ram and with PCB of 6 Layers .... I don't have this info about this model, I can't find it in the main Gskill page...
2) What about the others timings values(trfc, trcd, trdram....etc), which are set to auto...can I get specific timings values so I can get the most of my memory kit...or should I leave them auto?
I can upload any picture with the info you could need in order to get the answer I'm looking for. This is what cpu-z shows:
PD: Sorry for my awful english
