Model of the motherboard: GIGABYTE GA-P55-USB3
Model of the memory: 2 X 2GB DDR3 1600 (PC3 12800) Model F3-12800CL9D-4GBNQ
Model of the CPU: Intel i5-750 Lynnfield 2.66GHZ
What is the problem?
System ran fine for approximately 4 days. Began hanging on cold boot, giving MEMORY_MANAGEMENT Errors. RMAed the RAM, same errors with new RAM. Computer booted successfully once with one stick (2GB) in. Inserted second stick for a total of 4GB - would not boot. I tried using only one stick again, but I could not duplicate the earlier success. I have manually set the timings to 9-9-9-24, and the voltage is set at 1.5v. Are these timings correct, or is there something else I should change? I have an RMA order in for the motherboard as I believe I've ruled out the RAM as the culprit, but any assistance would be helpful.
