Which of these are your best 2x 2GB PC3-12800 for over/under-clocking?
http://www.gskill.com/products.php?index=179
http://www.gskill.com/products.php?index=87
http://www.gskill.com/products.php?index=185
http://www.gskill.com/products.php?index=220
http://www.gskill.com/products.php?index=222
http://www.gskill.com/products.php?index=221
http://www.gskill.com/products.php?index=243
http://www.gskill.com/products.php?index=226
http://www.gskill.com/products.php?index=249
http://www.gskill.com/products.php?index=248
http://www.gskill.com/products.php?index=247
Often the two go together....
If something OC's well with minimal voltage increase, then it's usually also a good under-clocker.
It must be flexible with latency timings...
So that when OC'ing one can loosen them, & when under-clocking or running at stock (I'll do that mostly), one can lower them.
The Eco series or the PI's look like they might be the best fit.
http://www.legionhardware.com/articl...cl7_4gb,7.html
http://www.hardwareheaven.com/review...=926&pageid=11
Thank-you.
Thank-you.
