Code:
Motherboard: Gigabyte GA-MA790XT-UD4P with latest Bios F7 Memory: 2x GSKILL F3-10666CL7D-4GBRH (8GB) CPU: AMD Phenom II X4 955
configuration. Though the system is running smooth with two sticks
(4gb). I already swapped the sticks to eliminate the possibility of
faulty sticks.
The system is running on linux and I use a prime stress test and memtest86+ to check the ram.
I already tried the following settings in the BIOS with no luck yet:
Code:
DDR3 Voltage Control 1.65V CPU NB VID Control 1.35V Memory Clock x6.66 1333MHz DCTs Mode Unganged CAS# latency 9T RAS to CAS R/W Delay 9T Row Precharge Time 9T Minimum RAS Active Time 24T 1T/2T Command Timing 2T TwTr Command Delay 5T Trfc0 for DIMM1 300ns Trfc2 for DIMM2 300ns Trfc1 for DIMM3 300ns Trfc3 for DIMM4 300ns Write Recovery Time 10T Precharge Time 5T Row Cycle Time 33T RAS to RAS Delay 4T
settings I try. Running with 4gb is pretty easy, I can actually use
stronger timings such as 7-7-7-21.
What else could I try to achieve a stable 8gb system?
