Model of the motherboard:
ASUS P6T SE
Model of the memory:
G.SKILL Trident 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL6T-6GBTD
Model of the CPU:
i7 920
Once a night I'm experiencing a BSOD of as a result of "Memory Management", and then it says it is dumping all of the memory and then the computer resets itself. Then it normally restarts and only 4GB of my 6GB shows up. I have no idea why it is happening. (I can normally open up my computer and reinstall the RAM and it shows up)
After my last BSOD last night, I googled suggested settings for my RAM in the BIOS and changed everything in the BIOS from AUTO to those settings. I'm hopeful this will solve the issues. Before and after I changed the settings, Memcheck ran (with 6 passes) with no errors and the windows diagnostic tool didn't show any errors either.
Questions:
- Could the AUTO settings on the voltage cause such a disruption?
- Are there any compatibility issues with my motherboard and RAM?
- Is it possible to have a bad stick of RAM with all of the diagnostic tools showing no errors?
Any ideas would be much appreciated.
ASUS P6T SE
Model of the CPU:
i7 920
Questions:
