Dear to whom it may concern:
Looking for some help in setting up F3-10666CL7D-4GBRH on the ASUS P5P43TD Pro motherboard running Intel Core 2 Quad Q9550 @2.83ghz. I have two kits for a total of 8gb running on the motherboard in dual channel interleaved mode. The BIOS detects the memory at 9-9-9-24 (while at these automatic settings everything runs fine). Whenever I go in and manually set the timing to 7-7-7-21 as per GSkill's specifications and apply the changes the system freezes while booting up usually at/before RAID controller initialization screen. I am only able to fix the issue by clearing BIOS completely (using jumpers) and starting over. What is disappointing is that the low latency of the memory was one of the primary reasons why these modules were picked over the others.
I guess, I am looking for help with some settings or voltage suggestions? The bios does have an extended amount of timing settings that can be adjusted. One thing that I was unable to find though is the Command Rate setting, it appears to be missing?
Thank you in advance,
-Sov13t.
-Sov13t.
