I have this board GIGABYTE GA-MA790FXT-UD5P with an Phenom II 955 BE with 2 kits of F3-12800CL8D-4GBTD (4 x 2 GB). So the memory are rated for 1600 but If I put on the bios 1600 it is very unstable. At 1333 with 8 gb no problem at all. It is possible that the chipset only support 1600 on 2 slots and not four? In that case, wich options and timings I should use to get better performance? Thanks.
It is possible to run 8 GB DDR3 1600 on 790FX?
Well I try the SB/HT voltage control to 1,4v and the NB voltage control to 1,4v and it runs fine for half hour and then hangs. So I want to try with only 4 gb to test each kit. Wich timigns do I need to use? I try on auto on 1600 and it put me on cas 11 and it is not stable, it is possible that this memory can't run on this motherboard correctly? Can you send me all the timings I need to put? I also try the voltage of the memory on 1,7v and no luck. Try unganged and ganged and the same.
What are the default advanced timing values when all 4 sticks are installed? The motherboard may not be picking some of them up correctly, causing instability.
Memory voltage will only need 1.65V max. The memory should always be set to UNGANGED. Let me know the timings and I will be able to further assist you.
Well, I think I found an error on the g.skill webpage. http://www.gskill.com/products.php?index=185
In the main board shows Intel, but in MB chipset, shows Intel X58,X48, P45 wich are correct because all of them are from Intel, but shows at the end AMD 7xx series. I think it should be said Nforce 7xx, like for example the 790i wich is a socket 775 platform. And this memory has xmp wich is also an intel feature, so with an amd motherboard they would work, but with differents and more relax timings, and differentes settings, like in compatible mode. And that's is the reason why I can have even stable only 4 gb kit on 1600 and 8 gb on 1333 works fine, with relaxed timings. Let me know, if what I'm thinking is correct and wich type of memory will work great for this motherboard. thank you for your help.
Ok, now I put 8 gb again, and can't past super pi 16k. So, it's unstable. These are the timings on auto, wich are different that it was on auto the last time it has the 8gb put on. I remember something like CAS 11, and now on auto it takes CAS 9, wich is very weird, maybe because I change the memory from one slot to another? Anyway, these are all the timings I have on AUTO.
frecuency 1333
cas 9
ras to cas 9
row precharge 9
minimum ras 24
command timing --
twtr 5T
trfc0 dimm 1 110ns
trfc2 dimm 2 110ns
trfc1 dimm 3 110ns
trfc3 dimm 4 110ns
write recovery time 10T
precharge 5T
row cycle 33T
ras to ras 4T
CHA procOdt 60 ohms
CHA DQS 1.25x
CHA Data 1.25x
CHA MEMCLK 1.5x
CHA Add/Cmd 2.0x
CHA CS/ODT 1.5x
CHA CKE 2.0
CHB procOdt 60 ohms
CHB DQS 1.25x
CHB Data 1.25x
CHB MEMCLK 1.5x
CHB Add/Cmd 2.0x
CHB CS/ODT 1.5x
CHB CKE 2.0
bank interleaving enabled
channel interleave enabled
DQS Training Control Skip DQS
CKE Power Down Mode Disabled
Memclock tri-stating Disabled
I have the same motherboard And processor you have, I had the same problems until I updated the bios to F6. Then set To optimized defualts, (I am useing F3-10666CL8D DDR3 1333 8 Gigs) The only changes I made were to the first four timming numbers 8-8-8-21, And kept the voltage @ auto 1.6v, With no problems. Check your Bios if it needs to be updated to F6. Hope this helps.Gigabyte MA790FXT-UD5P
AMD Phnome 2x4 955 Black 3.6GHz (O.C)
G.Skill 16Gig (4x4Gig)DDR3 1333 Dual ch.F3-10666CL7Q RIPJAWS-X
XFX HD4870 1GB 256Bit DDR5
CORSAIR 850tx 850Watt Power Supply
Cooler Master HAF932 ATX Case
Cooler Master V8 CPU cooler
Samsung DVD Burner Sata W/DL/lightscribe
Pioneer DVD burner USB W/DL/Lightscribe
2-WD 250 Gig HD
1-Hitachi 1 TETRABYTE HD
Windows 7 Home Premium 64Bit
What settings do you sugest for tRFC? They are set to 110ns right now.Gigabyte MA790FXT-UD5P
2-WD 250 Gig HD
I dont have 195ns in bios. I have 90 110 160 300 and 350ns I set it to 160ns and seems to be ok. And ddr voltage is set to 1.6v Thank you for your time and information..Gigabyte MA790FXT-UD5P
2-WD 250 Gig HD
What about voltage ?1,6 0r 1.65?Gigabyte MA790FXT-UD5P
2-WD 250 Gig HD
Mad5,
frecuency 1600
cas 9
ras to cas 9
row precharge 9
minimum ras 24
command timing 2T
twtr 5T
trfc0 dimm 1 160ns
trfc2 dimm 2 160ns
trfc1 dimm 3 160ns
trfc3 dimm 4 160ns
precharge 5T
row cycle 33T
ras to ras 4T
RQuallsJR,
1.60V should be fine. You can also use the settings above except 1333.
Keep me posted on the results.
