So I thought I upgrade my ram capacity and bought additional RipjawsX ram presumingly the same dimms as I already had
f3-12800cl9d
1600
cl9-9-9-24
I got them In the mail today and I was surprised to see that there are some differences between new and old ... The heat-sink is a little different which looks strange if installed,
CPU-z shows different stats (trc 33 instead of 40) and there Is a golden GB instead of BC on the new ones.
I have no Idea what It means so I have a few questions.
Will I have a performance disadvantage If the modules aren't exactly the same ?
What does GB and BC stand for?
Is It normal that they run at 800MHz if in dual-channel mode ?
overclocking worth it ?
GB BC
http://imageshack.us/photo/my-images/805/ramo.jpg/
cpu-z
http://imageshack.us/f/547/gcgb.jpg/
f3-12800cl9d
1600
cl9-9-9-24
GB BC
cpu-z
