Hello G.Skill community,
my today?s questions are about RAM timings, XMP and MemTest86+.
Hardware specs:
- Intel i7 3770K not yet overclocked
- Prolimatech Megahalems Rev.C
- Gigabyte Z77X-UD3H F18 BIOS (the newest non-beta BIOS)
- G.Skill RipjawsZ 4x4 GB PC12800 (http://www.gskill.com/products.php?index=427), compatible to the mainboard acc to manufacturer
- MSI GTX680 TwinFrozr III 2 GB
- Seasonic x-560 PSU
- 1 SSD, 3 HDDs
- Win7 64bit
For you to understand what I am currently on, I will try to give a short summary:
In the past 2 or 3 months, I had 2 bluescreens on my PC
(the most recent one error code 0x24), and now I want to figure out what?s going on.
After reading a lot through forums etc, I figured, it may be a good idea to do a Memtest (with MemTest86+) while I am at work, so it can complete a few cycles.
So I went to the BIOS, and noticed, my RAM timings were set to 11-11-11-28 (I guess), but my memory should have 9-9-9-24 (at least that?s what G-Skill shows on the web page). After activating XMP, it showed the correct timings of 9-9-9-24.
First questions:
1) Should my BIOS detect 9-9-9-24 timings normally on AUTO settings, or is it the usual way, that it detects the "higher" timings?
2) Is it recommended to activate XMP, or should I enter the timings manually (out of experience)?
3) Will the RAM Voltage be altered on XMP, too, or will it still work at 1.5 V? Does XMP need higher Volatges?
4) Are the timings from the BIOS used for Windows? Meaning: if BIOS detects 11-11-11-28, can Windows still use the 9-9-9-24 settings, or are the BIOS settings taken for Windows directly without change?
Well, MemTest86+ is now running, and it showed the timings of 9-9-9-24, just as I expected. But the RAM speed is given with 800 MHz.
5) Is this due to the RAM being DDR ram, so it is perfectly normal it only shows 800 MHz in MemTest?
It would be great if you could answer those 5 questions, as I am a little confused right now.
Thank you,
ZM
Hardware specs:
- 1 SSD, 3 HDDs
- Win7 64bit
First questions:
Thank you,
ZM
