First, sorry my english, not my first language :P
My components:
Memory: G.Skill Ripjaws X DDR3 1600 PC3-12800 16GB 2x8GB CL10
Motherboard: Asus P7P55D LE
CPU: i5 650 3.20Ghz
The two 4gb Kingston modules at 1333 that I used until now worked flawlessly.
If I plug the two G.Skill modules in the slots 1 and 3 the computer completely freezes at the BIOS screen. If I plug only one at the slot 1, the computer reaches the "initiating windows" screen for a second, thend freezes and then restarts. Windows detects some damage, but if I select "repair windows" a blue screen prompts.
I upgraded the BIOS and it didn't solve the problem
And yes, all my BIOS settins are at "auto"
Any help?
My components:
CPU: i5 650 3.20Ghz
Any help?
