Problem G.Skill RipjawsX f3-17000cl9q-16gbxm and Asus ASUS P8Z77-V Deluxe
  • Problem G.Skill RipjawsX f3-17000cl9q-16gbxm and Asus ASUS P8Z77-V Deluxe
    Hello.
    Help with a problem. Here such configuration.
    Intel Core i7-3770K.
    G.Skill RipjawsX <f3-17000cl9q-16gbxm> DDR-III DIMM 16Gb KIT 4*4Gb <pc3-17000> CL9.
    As a result the computer normally starts only on frequency of memory to 2000. Frequency of the processor didn't increase.
    The XMP profile was loaded.
    that became.
    1. Bios on the motherboard ? 1504 is updated
    2. Tension of DRAM = 1.75 (what here the maximum side-altar increased?)
    3. Increased tension of VССIO =1.15
    4. Tension of VCCSA =1.1 increased
    5. Memory delays increased.
    As a result the computer joins, the light-emitting diode of memory and a computer burns is switched off. And so around.
    But it is necessary to remove 2 pieces of memory, the computer turns on normally on frequency of memory to 2400 without a raising of any above the described tension.
    With 4 pieces of memory the computer doesn't pass inclusion.
    WHAT can I make?
    Can you post your BIOS settings, particularly the system voltages and the the DRAM times both basic and advanced
      CPU is the i7 3770k and it is overclocked at 4.7 GHz at a voltage of 1.35.
      DIMM voltage - 1.658
      VCCIO - 1.037
      PCH voltage - 1.048
      VSMVTT - .828
      VSA - .946
      PLL - 1.849
      Memory Timings:
      tCL - 9
      tRCD - 11
      tRP - 10
      tRAS - 28
      tRRD - 7
      tRTP - 8
      tFAW - 35
      tWCL - 8
      Command Rate - 2
      Secondary Timings:
      tWR - 16
      tRFC - 171
      tREFI - 7936
      tWTR - 8
      tCKE - 6
      tRTL CHA - D0: 40 D1: 40
      tRTL CHB - D0: 41 D1: 41
      tIOL CHA - D0: 3 D1: 3
      tIOL CHB - D0: 3 D1: 3
      Third Timings:
      tRRDR - 1
      tRRDD - 3
      tWWDR - 3
      tWWDD - 3
      tRWSR - 4
      tRWDRDD - 4
      tWRDRDD - 1
      tRRSR - 4
      tWWSR - 4
        You mention having these at 2400, yet they are 2133 sticks, what do they do with XMP enabled and profile 1 selected, need to get a stable run at 2133 and can then OC
          I loaded the xmp profile 1 or 2. The computer doesn't work. Works only at frequency 2000. But windows 7 isn't loaded correctly. I bought this memory, hoping for quality and check from the producer, and received problems. Changed already what there is tension and memory delays. At the 2133rd start of the computer it is not possible. Only if it is established 2 of 4 memory pieces. But bought as a whale.
            Have you checked w/ Asus to see if a new BIOS is in the works?
