Hi all,
I'm looking for some advice about ram timings for my new build.
I'm running
Motherboard: ASRock Z77 Extreme6
Memory: 2 x G.Skill F2-14900CL9D-8GBXL kits (4 sticks, 16GB total)
CPU: Intel i7-3770k
The system is running BIOS version 1.90 and is not overclocked in any way.
The ram timings are as suggested, 9-10-9-28.
The system is stable when running only two sticks, but when I run with four sticks, I get memtest errors. I've tried incrementally upping the voltage but even with the DRAM Voltage set as high as 1.65 I'm seeing problems with memtest (granted, there are fewer problems at 1.65 than at 1.5).
I'm not sure what my next steps should be here. Is it just not possible to run the ram at the listed timing with four sticks?
I'm running
CPU: Intel i7-3770k
