Model of the motherboard:MCP73M01H1 (Napa)/Foxconn
Model of the memory: Model F2-6400CL5D-4GBPQ
Model of the CPU: Compaq Presario SR5450F
My problem is that when I try to put in the two sticks of ram into my computer, one of two things will happen, my computer will freeze at the start of the computer(during the install phase and its weird because now every time I turn on my computer the install Bios thing will start up instead of the normal start up screen) or it will go past that and then say BOOTMGR, is corrupt, or sometimes a bluescreen. I can use one ram stick at a time, I can even use one of my old sticks of ram with it too, and it successfully starts up. Previously sometimes it would give me blue screens but that seemed to stop as of now. I swaped the sticks all around from slot 1 to slot 2 and I am pretty sure that is not the cause of this problem, so im not sure what i can be.
Thanks in advance,
FJTT
Thanks in advance,
FJTT
