I recently built a computer with parts purchased from newegg.com.
Motherboard: GA-MA78GM-US2H (GIGABYTE)
RAM: F2-8500CL5D-4GBPK
CPU: HD985ZXAGHBOX (AMD Phenom 9850 X4)
Problem: memtest (always test #5) fails when running all four sticks (8GB) at 1066. Running four sticks at 800MHz seemed OK.
I have tested the sticks individually in varying slots. I also tried running them paired up. These configurations (one, two, and three sticks) always pass.
Thinking that the motherboard could be the problem, I replaced the motherboard (same model). With the new board, I still get errors on test #5.
For both boards, I increased the DDR2 voltage to 2.1 and the Northbridge voltage to 1.4. The errors still persisted.
Thank you!
Thank you!
