Hello, I cant get this memory to run stable at 1066 in this motherboard. I can set Memclock to 800 and it will work with 2 sticks. I tested both sticks and with one stick installed at a time, both of the sticks are stable and run over DDR1100. I also have another issue I wrote to gigabyte about below. Is thier a possiblity of an SPD change so these work right? I saw something a few threads back with a 7750 and Asus Mobo.
Wrote to Gigabyte
Hoping for some fixes in the next bios update.. Im having issues with gskill memory. F2-8500CL5D-4GBPK http://www.newegg.com/Product/Produc...82E16820231166 The board will not post with 2dimms installed and the epp profile on auto. I have to install an old set of slow memory set the epp to disabled and set ddr800, shut the rig off and install the newer faster memory. The memory is rated at 2.2volts. I cant set the memory above 1.9volts or it wont post.
Gigabyte Response
There maybe stability issue with your memory, have you tried testing the other channel or any other types of memory to further test the issue?
You can test with the F2b bios posted on our website
http://www.gigabyte.com.tw/Support/M...S&FileID=14456
Things I have tried.
Bios Update
1.4 Northbridge Volt
Installed on Dimm 1&2 3&4 2&4
5000+ CPU = Both sticks work fine overclocked to 1066 in Dimm 1&2 Dual Channel
Set 1066 in bios and EPP to disabled and MemV to 1.9 will post but locks up or Blue Screen.
Over 1.9V = No Post = Clear Cmos =Installing ddr800 1gb stick. set timings & EPP to disable then power down swap in 2gb stick.
Should I also respond to gigabyte? I cant figure out if its the Mobo, or Mem I dont have other 2gb 1066 mem sticks.
Wrote to Gigabyte
Gigabyte Response
Bios Update
