I have read a miriad of forum post. I cannot get all 4 sticks to operate at the rated speed of PC2-8800 without numerous errors on memtest, and usually cannot get into Windows (7-64). I can get any 2 sticks in any 2 slots to operate fine at 1066 with virtually no adjustments other than setting the voltage manually @ 1.8 for the dram. The settings below under the title 4GB,1066,5-5-5-15-2 work with any 2 sticks. However, I can get all 4 sticks going, again with the same voltage adjustment, and tighter timings with no hassle at all PC2-6400. These settings are under the title 8GB,800,4-4-4-12-2. I have tried upping the MCH to 1.4, upptin the tRFC to 80 or 88, etc. Help!
I have the following:
rev. 1.6 of the EP45-UD3P
Hiper 880W PSU
EVGA nvidia 8800GT 512 SC
E8400 CPU (currently not ocd)
GA-EP45-UD3P BIOS Template
******Gigabyte EP45 UD3P******........4GB,1066,5-5-5-15-2........8GB,800,4-4-4-12-2
Processor Name: Memory Model Number:
Robust Graphics Booster...................................[Auto ] ...................[Auto ]
CPU Clock Ratio............................................. ...[9 X ].....................[9 X ]
Fine CPU Clock Ratio........................................[ +0.0]....................[ +0.0]
CPU Frequency [ ]GHz...............................[3.00GHz 333X9 ]........[3.00GHz 333X9 ]
******Clock Chip Control******
CPU Host Clock Control.......................[Enabled ]................[Enabled ]
CPU Host Frequency (Mhz)....................[ 333]....................[ 333]
PCI Express Frequency (Mhz)................[ Auto] ...............[ Auto]
C.I.A 2...........................................[Disabled] ..............[Disabled]
******Advanced Clock Control******
CPU Clock Drive....................................[800mV]..................[ 800mV]
PCI Express Clock Drive........................[ 900mV].................[ 900mV]
CPU Clock Skew...................................[0ps ]......................... [0ps ]
MCH Clock Skew..................................[0ps ]..........................[0ps ]
******DRAM Performance Control******
Performance Enhance [Standard ]
Extreme Memory Profile (XMP)...................[Disabled ]..............[Disabled ]
(G) MCH Frequency Latch...........................[Auto ] .......................[Auto ]
System Memory Multipler...........................[ 3.20B] ....................[ 2.40B]
Memory Frequency 1066............................[ 1066] ........................[ 800]
DRAM Timing Selectable..........................[ Manual] .................[ Manual]
CAS Latency Time...................................[5 ].......................[4 ]
tRCD.............................................. ........[ 5] ......................[ 4]
tRP............................................... .........[ 5]........................[ 4]
tRAS.............................................. .......[15 ]..................[12 ]
******Advanced Timing Control****
tRRD.............................................. .......[4]...........................[4]
tWTR.............................................. .......[4]...........................[4]
tWR............................................... .......[8] ..........................[8]
tRFC.............................................. .......[68].........................[68]
tRTP.............................................. ........[4]...........................[4]
Command Rate (cmd)...........................[2]............................[2]
******Channel A Timing Settings******
Static tRead Value .....................[6]..........[Auto] .............[6]..........[Auto]
tRD Phase0 Adjustment .............[0]..........[Auto] ..............[0]..........[Auto]
tRD Phase1 Adjustment .............[0]..........[Auto] ..............[0]..........[Auto]
tRD Phase2 Adjustment .............[0].........[Auto] ..............[0]..........[Auto]
tRD Phase3 Adjustment .............[0].........[Auto] ..............[0]..........[Auto]
tRD 2rd (Different Rank).............[6]..........[Auto] .............[6].............[Auto]
tWR 2wr (Different Rank) ...........[6]..........[Auto] .............[6].............[Auto]
tWR 2rd (Different Rank) ............[5]..........[Auto] .............[5].............[Auto]
tRD 2wr (Same/Diff Rank) ..........[8]..........[Auto] .............[8].............[Auto]
Dimm 1 Clock Skew Control..............[Auto ]...............................[Auto ]
Dimm 2 Clock Skew Control..............[Auto ]...............................[Auto ]
DDR Write Training...........................[Auto ] ..............................[Auto ]
******Channel A Driving Settings******
Drive Strength Profile.........................[ Auto]..............................[ Auto]
Data Driving Pull Up Level...................[ Auto] ............................[ Auto]
cmd Driving Pull Up Level....................[ Auto] ............................[ Auto]
ctrl Driving Pull Up Level.....................[ Auto] .............................[ Auto]
clk Driving Pull Up Level......................[ Auto] ..............................[ Auto]
Data Driving Pull Down Level..............[ Auto] .............................[ Auto]
cmd Driving Pull Down Level................[ Auto] .............................[ Auto]
ctrl Driving Pull Down Level..................[ Auto] ..............................[ Auto]
clk Driving Pull Down Level..................[ Auto] ..............................[ Auto]
******Channel B Timing Settings******
Static tRead Value ........................[6]..........[Auto] .............[6]..........[Auto]
tRD Phase0 Adjustment ................[0]..........[Auto] ..............[0]..........[Auto]
tRD Phase1 Adjustment ................[0]..........[Auto] ..............[0]..........[Auto]
tRD Phase2 Adjustment .................[0].........[Auto] ..............[0]..........[Auto]
tRD Phase3 Adjustment .................[0].........[Auto] ..............[0]..........[Auto]
tRD 2rd (Different Rank)................[6]..........[Auto] .............[6].............[Auto]
tWR 2wr (Different Rank) ..............[6]..........[Auto] .............[6].............[Auto]
tWR 2rd (Different Rank) ...............[5]..........[Auto] .............[5].............[Auto]
tRD 2wr (Same/Diff Rank) .............[8]..........[Auto] .............[8].............[Auto]
Dimm 1 Clock Skew Control................[Auto ]...............................[Auto ]
Dimm 2 Clock Skew Control................[Auto ]...............................[Auto ]
DDR Write Training.............................[Auto ] ..............................[Auto ]
******Channel B Driving Settings******
Drive Strength Profile..........................[ Auto]..............................[ Auto]
Data Driving Pull Up Level.....................[ Auto] ............................[ Auto]
cmd Driving Pull Up Level.....................[ Auto] ............................[ Auto]
ctrl Driving Pull Up Level......................[ Auto] .............................[ Auto]
clk Driving Pull Up Level.......................[ Auto] ..............................[ Auto]
Data Driving Pull Down Level................[ Auto] .............................[ Auto]
cmd Driving Pull Down Level.................[ Auto] .............................[ Auto]
clk Driving Pull Down Level...................[ Auto] ..............................[ Auto]
******Motherboard Voltage Control******
Load-Line Calibration...............[Disabled ]......................[Disabled ]
CPU Vcore ............................[1.22500V].....[Auto].........[1.22500V]........[Auto]
CPU Termination ....................[1.200V]........[Auto].........[1.200V]............[Auto]
CPU PLL ...............................[1.500V].........[Auto]..........[1.500V]............[Auto]
CPU Reference ......................[.760V]..........[Auto]...........[.760V].............[Auto]
MCH Core ............................[1.100V]..........[Auto].........[1.100V]............[Auto]
MCH Reference ....................[.760V]...........[Auto]..........[.760V].............[Auto]
MCH/DRAM Refernce .............[.900V]...........[Auto]..........[.900V].............[Auto]
ICH I/O ...............................[1.500V].........[Auto].........[1.500V]...........[Auto]
ICH Core ............................[1.100V].........[Auto].........[1.100V]............[Auto]
DRAM Voltage .....................[1.800V].......[1.800V]........[1.800V]..........[1.800V]
DRAM Termination ................[.900V]............[Auto].......[.900V]............[Auto]
Channel A Ref ......................[.900V]............[Auto].......[.900V]............[Auto]
Channel B Ref .....................[.900V]............[Auto]........[.900V]............[Auto]
*****Advanced BIOS Features******
CPU Multithreading................................[N/A].......................[N/A]
Limit CPUID Max to 3...........................[Disabled]................[Disabled]
No-Execute memory Protect.................[Enabled].................[Enabled]
CPU Enhance Halt (CIE).......................[Enabled].................[Enabled]
C2/C2E State Support.........................[Disabled].................[Disabled]
C4/C4E State Support..........................[Disabled].................[Disabled]
CPU Thermal Monitor...........................[Enabled] .................[Enabled]
CPU EIST Function...............................[Enabled]..................[Enabled]
Virtualization Technology......................[Enabled]..................[Enabled]
Hiper 880W PSU
