CM690
GA-EP45-UD3P F9 Bios Rev 1.6
Intel E8500
Nividia 9600GT
4 1TB Raid 5 Seagate
1 1TB OS
HD Homerun
Hauppauge 2250
CM 4 in 3
6 x 120mm case fans
Antec 850 watt PSU
Win Pro 7 64 Bit OEM
I recently purchased 8 gb of F2-8800SL5Q-8GBPI for a new build I am working on. It all seemed to be working great at first then I started bsod daily and when I thought the computer was the most unused like in the middle of the night. I was running Optimized Defaults. I ran Memtest and it failed on test 5. So I removed two sticks and left two in 1 and 3 and ran memtest and it passed two full passes. I swapped mem same result to full passes. So I installed all of it and tried again optimized defaults no luck. So I started searching the forum and ended up changing the following.
Mem Multiplier to 3.20B
Manual set timings to 5 5 5 15
CMD to 2
Dram Voltage 1.8
MCH Core to 1.4
tRFC to 80
I ran Mem test again and it seemed to be fixed it made two full passes than I let it run all night when I woke errors after errors all test 5 and I have seem some test 8. So I changed
Dram Voltage to 2.0
And ran again this time it failed instantly and locked up memtest could not exit had to reset. Any suggestions on what is causing this and what I could try next. I believe I am going to test some GS F2-6400CL5D-4GBPQ. I have 8gb. Should I leave it at optimized defaults or what. Thanks for any help. David
Intel E8500
Nividia 9600GT
1 1TB OS
HD Homerun
Hauppauge 2250
CM 4 in 3
6 x 120mm case fans
Antec 850 watt PSU
CMD to 2
Dram Voltage 1.8
MCH Core to 1.4
tRFC to 80
Dram Voltage to 2.0
