ASUS M4A78 Pro BIOS 1501
2 x 2 GB F2-8500CL5-2GBPK to see on Everest Ultimate Edition.
On the RAM it shows: F2-8500CL5D-4GBPK. (1066 Mhz)
CPU: AMD Phenom II X4 940 3000 Mhz.
It should run automaticly with 1066 Mhz but it only runs with 800 Mhz.
How to switch the right preferences? I only have bougt this type of ram by using the qualified vendor list from asus.
But i cant get this ram running with 1066 Mhz. So help please.
I have so many things tried to change on the board. I also have tried to increase the Voltage of NB and Voltage of RAM (2.08 Volt)
When I increase the Voltage of NB the system does?nt start anymore.
An answer in german language would bei nice.
AMD Phenom II X4 940 CPU. ATI HD2600 XT 256 MB Grafik. Windows 7 x86 or Windows Vista X64 & X86 checked.
500 GB Samsung F2 HD502Hi HDD. Power Supply 700 Watt SuperFlower. DVD Burner Samsung Double Layer.
Also a had a lot of Problems on a Asus M4N78 Board, only 800 Mhz stabal running with these G.Skill Ram?s.
