Motherboard: GA-P35-DS3L F9 Bios
CPU: Q9550
Memory: F2-6400CL5D-4GBPQ two pairs
Trying to get this board to post with 8gb only 6gb will post. Each stick was tested individually in the memory slot closest to the CPU with memtest86 10+ passes with zero errors. Settings below were used with 0.3+ ddr 0.3 + fsb 0.3+ mch no post. Ram was set to 667 no post. Refresh to act 68 , write to precharge 8-10 no post. The system will post with 3 sticks yielding 6gb not 4 sticks. with 8gb the system powers on, powers off, powers on powers off, third time powers on no beep no post nothing.
People on newegg seem to run this combination fine with 8gb's. I read about 5 reviews. My settings are below. I have tested these sticks on Two DS3L motherboards both exhibit the same behavior.
CPU: Q9550
