Originally posted by berserker_b2k
View Post
F2-8500CL5D-4GBPI-B on GA-MA790X-UD4P
Originally posted by berserker_b2k View PostI've run the Linpack standard test for 25 passes, 18 minutes, no errors. Vista didn't BSOD either.
Linpack shows only 2043MB free... do I have to boot into safe mode so I can check further?
Thanks a lot genetix, looks like we (you) made it"Sex is like freeware, shareware on weekends. When do we get to open source?" -TwL
CPU 200
Memory 5.33
Unganged
CAS# latency - 5T
RAS to CAS R/W Delay - 5T
Row Precharge Time - 5T
Minimum RAS Active Time - 15T
1T/2T Command Timing - 2T
TwTr Command Delay - 4T
Trfc0 for DIMM1 - 127ns
Trfc2 for DIMM2 - 127ns
Write Recovery Time - 8T
Precharge Time - 3T
Row Cycle Time - 25T
RAS to RAS Delay - 5T
Increase DDR2 Voltage to 2.1V
Northbridge Volt Control 1.2V
I tried these settings with the f8 bios and windows will not load at all. I currently have my sticks in 1 and 3 but it appears maybe I should be in 1 and 2?
Any other ideas of something I may have missed?
....and in AMD speak it's ganged or un-ganged (ganged being dual channel) - and to a degree, I think it's just another way for AMD to try and distance itself from Intel and the long standing set of 1,3 and 2,4
Personally, I'd wish they would take the money they put into coming up with these 'different' things and put it into the R&D on the MCs
Tradesman, you as most people are a bit confused about the ganged vs. unganged subject.
First of all you can run dual channel in both ganged and unganged mode.
Running ganged means that the memory controller splits the data into 2 seperate 64 bit lanes (2x64 bit).
Unganged mode consolidates the data into one 128 bit lane (1x128 bit).
You would benefit in ganged mode when running single threaded applications.
You would benefit in unganged mode when running multi-threaded applications.
Myself and others over at the AMD forums ran benchmarks while running single threaded games in ganged mode.
Definitely higher bandwidth running ganged versus unganged during these benchmarks.
Subsequently, higher bandwidth running in unganged mode with multi-threaded benchmark programs.AMD Phenom II X6 1090T@ 4.2GHz
ASUS Crosshair V Formula
Creative SB X-Fi Xtreme Gamer
Corsair HX850W Modular
2x Win 7 Home Premium (x64)
I'm very sorry, but after reading my post, I had my info backwards:
Ganged.....1x128 bit
Unganged.....2x64 bitAMD Phenom II X6 1090T@ 4.2GHz
