register
My goal is to hit 2000 mhz, I'm close but voltage offset is kinda high. Easiest way to push non k cpus up though. At ~4.5 GHZ on the cpu. I might have to loosen timings, hoping I can stay where I am at currently. Volt offset for cpu is +.06, temps reach the 70's in Intel burn test, and sometimes in prime. All of my other temps look good.
Took a long time to get stable. Had to drop my CPU clock. Temps are a lot better too. RAM voltage is at 1.65...which is kinda high, and offset of .04
Finally hit 2000mhz stable. Ran it through multiple times on intel burn test at ten passes each run using different size memory just to be sure.
One kit of two dimm in dual channel configuration. With ivy bridge, using four dimms can be an advantage with with some benchmarks (if your cpu can pull of the same timings vs two dimms).
http://puu.sh/4cykn.jpg
Can't pass intelburntest if I go higher, might stop messing with fsb for now. I think my new psu is the only reason for stability lol.
