I recently purchased a set of G.SKILL Ares Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-1866C10Q-32GAB and I am having trouble with stability.
Build
CPU- Intel Ivy Bridge 3770K
MD- EVGA Z77 FTW (151-IB-E699-KR)
GPU- Sapphire Radeon 7970 HD 3GB
800 W power supply
Cooler master case
When I initially installed the memory, it was set at 1333Mhz. I have only been able to get the system to boot when then memory is set at 1800MHz with timings of 10-11-10-30 at 1.5V. Any recommendations to get this to the specified 1866Mhz or even higher. Also, would you recommend trying to lower the CAS timing or just stick with higher MHz. This is only my second build and am by no means an expert.
Build
800 W power supply
Cooler master case
