ASrock Z77 Extreme4 - GS Ripjaws Questions
  • #31
    I'm not a big fan of liquid cooling and try and stay away from building with them, from what I've run into, there are a number of reasonable priced fan based heatsinks that do just as well or better in a non extreme setting. At the lower end the CoolerMaster 212 EVO is a great one ($35) the Zalman 9000 series is more mid to upper and then I lean towards Noctua on the higher end...Liquid helps keep the extreme higher end temps down a few degrees, but even with a 212 EVO and single fan I seldom go over 80F and I am often really pushing the system, i.e. bringing up Win8 in a VM and running BM programs in both 7 and 8 at the same time.
    • #32
      New Observer Comments
      Folks, Tradesmen/DonMilagro and others,
      I have been studying this thread and wanted to thank you all for your the quality of info and details provided.
      Recently I ordered a custom made pc and in hindsight realized that I am not particularly happy about Ram provided which prompted me to find the G.Skill product. Anyway, just wanted to jump in and say hello. I should receive my pc in mail on Thursday and begin setting it up.
      I am trying to be careful to not derail this thread off topic. But it appears that my PC is equipped with same MB as this thread and I am interested in upgrading the Ram to F3-1866C8D-16GTX that was discussed in this thread. So it appears that this thread may be a good starting point to dial in some of the settings to tune PC for set up of the mem sticks that I referenced.
      So for now I say hello and am very happy that I have found this G.Skill product and quality of forum. Will be checking back soon to offer specs and see where discussion goes.
      Take Care all
      .....the new guy
      • #33
        From one Tman to another T-man, we'll be around, I've had this mobo since about the time it came out, and there's been BIOS problems here and there, but it's been great, I currently am running a 3570K on it at 4.7 and 32GB of the 2400 Tridents
        • #34
          Welcome T-man, you'll find lots of quality help here with GSkill RAM and SSDs.
          (Boy, this will get confusing.)
          I'm sorry Dave, I can't do that.
          • #35
            Sorry about Screen Name
            Hey Guys,
            thanks for the welcome. By the way tradesman, did not pick up till recently that you go by name tman as I had not seen tman in threads which I reviewed. Purely coincidence that I picked T-man. I actually sent administrator a note asking him if he could change my screen name to tonester. Perhaps you can now guess my first name.
            Anyway, just setting up pc now / this weekend. I think I will see if I can fix my ac in this room before working the OC. I live in Hawaii so ambient air needs some improving in this room.
            Take Care...
            • #36
              We can make that change, so keep in mind if the next time you try to sign on but can't, try tonester.
              • #37
                No worries, as far as I'm concerned
                • #38
                  just wanted to leave feedback that I am running a steady and reliable 4.4 OC on the i5-3570 cpu with voltage at 1.272.
                  ASRock extreme 6
                  Thermaltake Case Chaser 41
                  Asetek Cooler labeld for Intel
                  etc. more to follow
                  Was wondering if you could point me to an ASRock download where I can keep track of system temps that can be viewed outside of the Bios. Essentially, looking for system moniter tool kit if available.
                  This is all I could find and does not seem that anything here is a good fit for system monitoring?
                  http://www.asrock.com/feature/index.asp
                  • #39
                    Should have a utility program w/ the mobo - ASRock eXtreme Tuner - there's also a number of 3rd party apps like Core Temp
                    • #40
                      Tman,
                      thanks for the direction. I was able to find it in the downloads section related to that particualr motherboard instead of in the general rescources were I was looking.
                      Next, wish to keep an eye on the temps under load and also see about the fans.
                      Thanks Again...
                      • #41
                        HI,
                        ok. So in the interest in offering settings here you go:
                        Performance:
                        http://www.screencast.com/t/1mVFgXxip4Ed
                        Settings:
                        http://www.screencast.com/t/4d1Mm2Sb
                        Hardware:
                        http://www.screencast.com/t/zIaZjeV3EaH4
                        So as you can see I am using the voltage offset and also have Turbo boost enabled at +.02.
                        So I would appreciate any comments on how robust these settings are in support of [ TridentX ] F3-1866C8D-16GTX. I am not looking for any crazy OC on the ram. But would enjoy some improvement if possible.
                        My intent is to dial in everthing on CPU settings before doing anything elese. I am actually pleased with current settings but look forward to hearing what others may think?
                        Thanks..
                        • #42
                          The CPU configuration looks fine, now you just need to work on memory.
                          Manually input settings for the memory to achieve rated specifications.
                          • #43
                            Selection of Ram
                            GSkill Tech,
                            thank you for the confirming remarks on settings.
                            Ok, so now the next piece is the selection of Ram. I read in your forums that the Tridant is very well suited for the Ivy Bridge. It also appears that this is your performance line which I want.
                            I am reasonably confident that 16 gigs of ram is sufficient size for my needs. So it looks like the F3-1866C8D-16GTX is a very good fit for me on the size and performance for an i5-3570. Please confirm that is ram is suitable as high performance for this processor.
                            Last question for now: if for some crazy reason I wanted to add in another 16 gigs later is this possible to add in additional same sticks if necessary.
                            Thank You for all your time.
                            • #44
                              Gskill,
                              I see you have not updated my screen name. Ok, so we now have all rights reserved for T-man back to tman.
                              Thanks.
                              • #45
                                Oops on my last, not = now.
