[ TridentX ] F3-2666C11D-8GTXD /Gigabyte G1 Sniper 3 / Intel I7 - 3770K
  • #16
    but I did see the temp rise from the normal 41-46 c
    to 51-56c when it was oc at 4.4ghz
    • #17
      at this point I want to know if there is a better memory set for this board I can always use this memory in another system , sorry this did not work out as planned
      • #18
        by the way when this memory was tested in this mother board what bios ver . was used?
        • #19
          I'll drop GSkill Tech a note to take a look, he'd prob be the one to have that info.
          • #20
            There is a beta Bios out for this motherboard , just put out for windows 8 , I am going to give that a try.
            cross your fingers
            • #21
              Well finally some good New the Beta Bios worked veryyyyy well !
              Plus XMP is enabled and stable so far . I will be doing a lot of testing before posting the Beta Bios picture and settings .
              I will tell you that windows 7 rated the system @ 7.8 and that is with just a single SSD drive , I did order the second drive to run this in a Raid 0 config . I am sure the system will at that point be a true gaming rig .
              • #22
                By the way I would like to thank Tradesman for pushing me to keep trying , without him I would have given up
                Thanks a ton Man !!!!
                • #23
                  PerformanceTest http://www.passmark.com/baselines/V8...?id=1796316402
                  • #24
                    Glad to hear it, sorry it didn't go faster, Enjoy! and you'll love the RAID 0 !
