[ TridentX ] F3-2666C11D-8GTXD /Gigabyte G1 Sniper 3 / Intel I7 - 3770K
  • [ TridentX ] F3-2666C11D-8GTXD /Gigabyte G1 Sniper 3 / Intel I7 - 3770K
    This is a new build
    Windows 7 Ultimate x64 (6.1.7601) Service Pack 1 OS
    C/drive: Intel SSD 120 Drive 120GB
    SATA 6Gb/s 550 MB/s / 500 MB/s
    SATA 3Gb/s 280 MB/s / 260 MB/s
    25,000 IOPS / 80,000 IOPS
    (Note) waiting on another Intel SSD 120 Drive 120GB, to run C: drive in Raid o .
    D/ drive: HL-DT-ST DVD-RAM GH22NS30 SCSI CdRom Device
    Intel i7 3770k @ 3.50GHz / turbo 3.90GHz = Enabled
    Hyper-Threading = Enabled
    Gigabyte G1.Sniper 3 motherboard ( Bio ver. F7 latest )
    all setting set to Auto or Default
    Memory:[ TridentX ] F3-2666C11D-8GTXD
    Specifications Model Number F3-2666C11D-8GTXD
    System DESKTOP
    System Type DDR3
    CPU 3rd Generation Intel Core Processors
    M/B Chipset Z77
    Capacity 8GB (4GBx2)
    Dual Channel kit
    Tested Speed DDR3-2666 MHz (PC3-21300)
    Tested Latency 11-13-13-35 2N
    Tested Voltage 1.65V
    Type 240-pin DIMM
    SPD Speed 1600 MHz
    SPD Voltage 1.5V
    Height 54 mm / 2.13 inch
    Warranty Lifetime
    Fan lncluded Yes
    Features Intel XMP (Extreme Memory Profile) Ready
    Qualified Motherboards List
    ASUS MAXIMUS V GENE
    ASUS MAXIMUS V Extreme
    ASUS MAXIMUS V Formula
    ASUS P8Z77-V DELUXE
    ASUS P8Z77-V PRO
    Gigabyte GA-Z77X-UD5H
    Gigabyte GA-Z77X-UP5 TH
    Gigabyte GA-Z77X-UP7
    MSI Z77A-GD65
    MSI Z77A-GD55
    MSI Z77A-G45
    MSI Z77 MPOWER
    AsRock Z77 OC Formula
    Nvidia GeForce GTX 580
    GPU processor: GeForce GTX 580
    Driver version: 306.97
    DirectX support: 11.1
    CUDA Cores: 512
    Core clock: 772 MHz
    Shader clock: 1544 MHz
    Memory data rate: 4008 MHz
    Memory interface: 384-bit
    Total available graphics memory: 6890 MB
    Dedicated video memory: 3072 MB GDDR5
    System video memory: 0 MB
    Shared system memory: 3818 MB
    Video BIOS version: 70.10.48.00.82
    IRQ: 16
    Bus: PCI Express x16 Gen2
    Power Supply : ULTRA PRODUCTS X3? 1000W Power Supply w/ Modular Cable Management, 24-pin ATX, ATX12V, SLI Ready
    Mfg. Part No. ULT40064
    Item Code. PSU-ULP-ULT40064
    Specifications:
    AC INPUT 115V/230V 10A/6A 60/50Hz
    MAX OUTPUT CURRENT + 5V + 3.3V +12V -12V +5VSB
    28A 24A 70A 0.8A 3A
    1000W Max Combined Watts 160W 840W 9.6W 15W
    980W 19.7W
    1000W
    Total Output Power:
    1000W (Full Load, Nominal Input Voltage)
    Efficiency:
    85% at Typical Load
    Input
    AC Input Voltage: 115V/230V
    AC Input Frequency: 50-60Hz
    AC Input Currents:
    ?13A (RMS) for 115VAC input
    ?8A (RMS) for 230VAC input
    Ok here is the good part :The system is rock stable with out using Intel XMP (Extreme Memory Profile) profile1 or profile2
    The bad part is I got this for one reason ; To run it @ Tested Speed DDR3-2666 MHz
    1. The system is unstable using XMP profile1 or profile2
    2. I have tried Sticky: How to enable XMP/ manually overclock G.SKILL memory with GIGABYTE Z77 & Ivy Bridge ( did not work, still unstable )
    3. At this point I am asking for Help Please, if I missed adding any info please just ask .
    Thanks for the help !
    Do you have the latest BIOS? Can you post your system voltages and DRAM timings, both the base and the advanced/secondary timings?
      I do have the latest Bios installed , I will take picture of what you asked for and post it here , and thx for the quick reply !
      If anyone else that have any clue please feel free to add your remarks
        GSkill tech will prob be in today, and I'll be back later this PM, we should be able to get this straightened out
          Here are the bios picture you asked for
          Default setting
            Here are the Bios settings for Xmp 1
            This is where the system becomes unstable
            any input will be very helpful .
            Thanks in advance
              In your comments you indicate 8GB yet the BIOS screen shots appear to indicate all four slots filled w/ 4GB sticks, are only running two sticks (the model indicated) 2 sets of that model (4 sticks) or a true single package quad set? If running two sets (that in of itself can be problematic, especially with high freq sticks) then XMP won't work as it's programmed by the packaged set, so you'll have to set up manually. Need to know exactly what you are running/trying to run
                :[ TridentX ] F3-2666C11D-8GTXD is a Capacity 8GB (4GBx2) Dual Channel kit
                there are only two stick in this system and I am trying to run them @ 2666.
                or do I need to send this back and get another set that is better for this set up,
                and if we do set this up manually what are the settings to do this
                I plan the run this system at stock speed only , but I do plan to run the SSD drive
                in a Raid 0 config
                  To run at 2666 you'll need an OC of prob better than 4GHz, prob more like 4.2 or better, at stock it will run up to 1600, might squeeze 1866 with the turbo enabled.. Try initially at 4.4GHz, with the DRAM at 1.65, VTT at 1.14, IMC at 1.12, stock timings on the DRAM and see how that goes
                    tubo enabled or not ?
                      sorry for typo , turbo enabled or not when oc to 4.4ghz.
                        I am running on water cooling so the over clock is not a problem , I just need to know if I need to disable the turbo on the cpu or not
                          I myself just set it by the multiplier, can leave speedstep on, which will drop you if not needed
                            ok I am going to try the oc @ 4.4 , and set the cpu turbo to disabled
                              Failed to post , with or without cpu trubo enabled or disabled
