How do I interpret the model number?
  • How do I interpret the model number?
    I purchased the ASUS Rampage III Formula motherboard.
    A couple of questions. What is the difference between the F3-16000CL9T-6GBTDD and F3-16000CL9T-6GBRHD? The ASUS Qualified Vendor List only mentions the F3-16000CL9T-6GBTD/-6GBPS which I can't find on Newegg. Does this mean the first two aren't qualified? I don't understand the DD, HD, TD, PS endings on the model numbers.
    Help! Just looking to purchase some memory that works with this motherboard!
    Tim
    the last two are the individual model type - other using example F3-16000CL9T-6GBRHD
    F3 - DDR3
    16000 - Speed
    CL9 - CAS Latency in this case 9, else CL8, CL7 etc
    T - Triple or three, S - Single (1 Chip), D - Dual, (2), Q - Quad (4), T2 -3x2 (6 sticks)
    6GB - Total DRAM of set, here 6GB
    RH - Model ID (could be diff models of CL9 sets with diff timings or made w/ diff ICs
    D - Indicates set comes w/ a fan
    There's another thread that touches on a few of the differences in model designations the the Ripjaw designations of RL RM RH (Ripjaws Low Medium High) here:
    http://www.gskill.us/forum/showthread.php?t=3892
      Compatibility with ASUS Rampage III Formula
      Thanks.
      Do you know if all of these are compatible and/or qualified for the ASUS Rampage III Formula?
        Believe all should work, it may depend on the CPU how much tweaking, if any is needed, i.e. voltages. The F3-16000CL6T-6GBPID set may be the best bet as it's CL6 and 1.65 rated, since it will allow more leeway for tweaking to meet your needs.
          All triple channel kits will work with this motherboard.
            Cpu
            Thanks again. Purchased the Intel I7-950.
            Intel Core i7-950 Bloomfield 3.06GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor BX80601950
              Should be no problem, Enjoy
