Basics:
ASUS P9X79 WS
G-Skill F3-17000CL9Q2-32GBZH
WINDOWS 8 64 Bit
Ok this system ran for about 1/2 year under Windows 7 (default settings) not a single problem. I didn't even pay attention to the memory timing.
Then I updated to Windows 8. Initially under BIOS level 3401. Every 10-20seconds WHEA or IRQ not less... or Memory blue screen errors.
I modified a few BIOS parameters, but the one that stabilized the system was clocking the memory down to 1333. (ridiculous considering that this is 2133 memory).
Recently I updated to BIOS 4202 in the hope I can configure system back to full spec. I can't run the system for more than 120 seconds under Windows 8 with crash to the blue screen.
What the flying fadoodle.
Of course there are about 60+ parameters that could be adjusted (and I tried 10 obvious ones but it probably got worse).
If I just keep the system up in BIOS Configuration screen. it doesn't crash at all (at least not for 12 hours). If I boot into Windows 8 and logon, it is a question of time when the errors occur.
Do I need to buy Kingston Memory
. Or is there hope.
ASUS P9X79 WS
WINDOWS 8 64 Bit
. Or is there hope.
