Recently built a new computer specs:
16gb of F3-10666CL9D
Intel 520 180gb SSD
Intel x-25m 120gb SSD
Various Hard Drives
470gtx
Sabertooth x79 mobo
I started to have issues with the Intel 520 failing integrity check, and also with Google Chrome and other programs crashing, but no BSODs or anything.
So I ran tests all around on my system and prime 95 and what not. Everything passed except memory.
So after some testing if I have 8gb of RAM installed, everything works as intended and Memtest passes. If I put in 12 or 16gb then memtest fails. I have tried using different slots and moving around the RAM sticks and nothing seems to make a difference. I have also tested the RAM stick by stick and it seems to pass. So I'm thinking it's a settings issue.
I am on the latest BIOs on my mobo.
Help?
I can provide whatever information is needed, though I won't have access to it till about 4 hours from now. Thanks.
UPDATE CLICK HERE FOR SCREEN CAPS OF ALL THE SETTINGS I COULD FIND THAT I THOUGHT WOULD BE RELEVANT.
Intel 520 180gb SSD
Various Hard Drives
470gtx
Sabertooth x79 mobo
Help?
I can provide whatever information is needed, though I won't have access to it till about 4 hours from now. Thanks.UPDATE CLICK HERE FOR SCREEN CAPS OF ALL THE SETTINGS I COULD FIND THAT I THOUGHT WOULD BE RELEVANT.
