Gskill Falcon SSD will not upgrade FW
  • Gskill Falcon SSD will not upgrade FW
    I have tried every version of firmware upgrade and all methods posted on here with no luck. My drive is a Falcon I 64GB drive purchased about 10 months ago. I have also recently been getting BSOD's and when i reboot it does not recognize the HD until I turn off the computer and unplug it and plug it back in. How can I get this drive fixed and have the new version of FW installed onto it?
    wow still not a single reply from a tech????
      Download Falcon FW 1916 tool and Falcon FW 2030
      You need other computer or that to finish steps 1~3. And steps 6~7 need a usb boot disk.
      1. Power off computer and plug supplied pin jumper onto your SSD then boot your computer.
      2. Use 1916 FW tool clean function erase ssd.
      3. Install FW 1916.
      4. Power off computer and remove jumper from ssd.
      5. BIOS set storage to "IDE" mode.
      6. Use usb boot disk boot-up computer.
      7. Upgrade FW to 2030.
        problem is I can't get the process of the cleaning/inslatt of new firmware to complete. I always get some error and it undoes everything.
          so no gskill rep is going to respond eh? I am going to submit an rma then thanks for nothing
            sorry for not replying earlier.
            Have you already sent you SSD to us?
            we will exchange a new one to you.
