Hello, I recently bought the 60GB Pro SSD from newegg.. got it and my brand new Obsidian 800D case (pretty sweet, awesome if gskill ever goes that direction 'case building') A side note.. it does NOT work with the hot swap bay interface of the machine, which wasn't a huge deal remove back panel and ran the wires through same route reguardless.
Now that I got the history out of the way here is my issue. I installed Win Vista 64-bit OEM version fresh onto the drive. Upgraded immediately to Win7 64-bit OEM (Upgrade package deal at newegg awhile back). Since then I read the common tweaks etc, and changed all of my configurations and don't notice a difference at all really.. but my computer was fast to begin with so I thought nothing of it. However, the biggest part.. switching to "AHCI" mode from "IDE" in my BIOS.. causes a blue screen of death.. then I reset my BIOS settings it instantly boots up.
What approach should I take to make sure I am optimizing the performance of my SSD? I was a bit overwhelmed seeing I got my brand new case the same day and spent 5 hours moving my rig and my SSD configuration wasn't at the forefront of thought at the time as I rushed to get my OS on my system. (Broke my IDE input it seems during MB transfer
so my CD-ROM wouldn't work.. I have ordered a SATA drive)
It has been an ordeal and I have everything working, except my SSD is not the "amazing fast you won't believe its the same computer" results. I very seriously doubt it is the quality of the product as every gskill product I have bought exceeds the competition. Instead I know I am at fault, which is fine.
Shall I wipe my SSD and reinstall my OS AFTER I setup "AHCI" mode? Or would there be an alternative reason I have system instability (BSOD) when I boot now that my OS is setup? Is there any way to fix this without reinstalling my OS?
System Specs:
MB: ASRock P55 Extreme LGA 1156 Intel P55 ATX Intel Motherboard
Processor: Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor BX80605I5750
SSD: G.SKILL Phoenix Pro Series FM-25S2S-60GBP2 2.5" 60GB SATA II MLC Internal Solid State Drive (SSD)
RAM Set 1: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBRL
RAM Set 2: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
RAM FAN: G.SKILL FTB-3500C6-S Fans
GPU: GIGABYTE GV-N460OC-1GI GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
(Included mostly all of my system specs to be throughout for any known complications)
Thanks in advance!
so my CD-ROM wouldn't work.. I have ordered a SATA drive)It has been an ordeal and I have everything working, except my SSD is not the "amazing fast you won't believe its the same computer" results. I very seriously doubt it is the quality of the product as every gskill product I have bought exceeds the competition. Instead I know I am at fault, which is fine.
System Specs:
Thanks in advance!
