register
I am having a problem with steps 5 ad 6 of the upgrade process. I ca't fid the drive or file to delete ad replace. ay help with this would be appreciated.
Did you make sure to hold down the pin while inserting the USB connector? Check that the pin is thin enough to be fully inserted, or it might not be pressing down the button correctly inside.
If both of the questions above are "yes", then a drive with 64KB capacity should appear in "My Computer" or "My PC".
