First of all I have Km780r mx brown red led keyboard. And while I press some keys, I hear spring noises (Like when you compress a spring) but not all of them. For example R key does not produce spring noise but many of others do. Why it is like this?
Is this a faulty keyboard or is it ok? (Bought from amazon) What about warranty? I live in Turkey do I need to ship it back to US? It would cost more than keyboard itself.
And other suggestions:
I hope these suggestions will make GSkill keyboards better. Thank you.
- Set volume slider led brightness according to key background brightness levels. In my case if I click brightness button, volume led only flickers.
- Add a software option for system language change macro. Similar to ALT + SHIFT but direct set rather than a switch.
- When I installed the software, it tried to update firmware but said FAILED although keyboard got restarded. There is not any problem right now and if I now open firmware update app, it immediately closes. I think firmware updated successfully but it just said FAILED.
- Add a software option to set volume slider sensitivity. Currently it changes +2 -2.
- There must be indicator for Volume Mute. I think it would be good if mute key`s led turns on when volume muted. Or the exact opposite.
- Change name of App.exe to a related name.
- Sometimes if you connect usb soundcard and then unplug it, volume level indicator gets stucked.
