tl;dr: macro record function too short.
It seems I can only record a macro for about 20 seconds with the MR key or software. Sometimes though, this just isn't enough; or in my case, at any time. I need minutes worth for what I want to do.
However, I know the keyboard can do it. This isn't even an exuberant concept - minute long macros. I've tested by splicing together two 20 second macro scripts together, and the keyboard will play it however long it may be.
So my question is: why the limit? Is it the software's fault? Is this something that's going to be updated, or is there a way to circumvent it that I'm not aware of?
