Hello guys, hope you are all doing fine!
I'd like to ask what's the difference between these 2 kits as they are separated even though they are both 2x16GB same speed, latencies etc. Where's the difference?
https://www.gskill.com/product/165/3...39G16GA2-TZ5RK
https://www.gskill.com/product/165/3...39G32GX2-TZ5RK
Is it just cause of the 64 v 32 gb difference? Shouldn't it be just 1 part number? What's the "GX2" and "GA2" stands for?
