Trident Z Lighting Control software has been updated to 1.00.31
This is a sticky topic.
  • Trident Z Lighting Control software has been updated to 1.00.31
    The TZLC software has been updated to 1.00.31.
    This update includes a critical fix to some situations where software conflicts may cause the module to no longer be detected. It should also resolve some software conflict issues causing the RGB to no longer be functional.
    Download page link:
    https://www.gskill.com/download/1502...-Elite,-Z5-RGB
    Direct download link:
    https://www.gskill.com/gskill-device...l-v1.00.31.zip
    The direct link leads to v1.00.30, this one is for v1.00.31:
      This version solved one problem and created a very big one:
      Problem solved: system no longer crashes when loading RGB software and I can actually customize the lighting.
      Problem created: two of my four modules now seem to be dead. I've moved them from one slot to another and the same two don't work no matter where they are and the other two work no matter where the are. It's hard to imagine that RGB software can kill my memory but installing the update was the only thing I did.
        Hey theNEOone
        If the two modules now do not lighten up during the P.O.S.T. and can no longer be controlled even after switching slots, then a RMA is recommended.
        Please also double check the software version, since your description fits the issue that was present with V1.00.30 and was resolved with V1.00.31. So make sure to update to the latest version before installing the replacement.
        Best Regards
        Cody
          Thanks - I believe I did have .30 installed and not .31. The website had the wrong version (really guys?!)
          All is working now with .31, thankfully. I was still in the return window w/ Amazon, so I just exchanged my modules for new ones directly with Amazon.
            You are right, the initial download link was wrong and only got fixed after the weekend. Sorry for your trouble!
            Best Regards
            Cody
              Hello! I registered to just send some feedback:
              I have got:
              Trident Z5 Neo RGB F5-60000J2636G16GX2-TZ5NR
              Software: G.SKILL Trident Z Lighting Control v1.00.37
              OS: Microsoft Windows 11 Pro 25H2 (26200.8457)
              I installed Trident Z Lighting Control just to turn off RGB of modules. It automatically start on each boot and i close it after it. Annoying, but whatever.
              After i installed NVIDIA Driver v610.47 with new NVIDIA App i noticed that there are no longer Trident Z Lighting Control after boot.
              So, i watched Event viewer and yep... there was two errors from Trident Z Lighting Control.
              It can't be NVIDIA driver, because i would get it long time before (on previous versions). Probably NVIDIA App it is.
              I deleted NVIDIA driver (with DDU) and installed same Driver ONLY (without NVIDIA App). And Trident Z Lighting Control start working FINE.
              I didn't even touched Trident Z Lighting Control! It keep starting as it did before.
              SO,
              1. There some kind of conflict between Trident Z Lighting Control and NVIDIA App;
              2. I HOPE G.SKILL add in new version of Trident Z Lighting Control an option to: 1. Apply settings, 2. Auto close software after it apply settings.
