I had noticed some unusual behavior with four sticks of G.Skill Trident RGB DRAM, and started examining what could cause it. I started with CPU-Z. It showed some strange SPD information on the sticks. Then I tried Thaiphoon burner to read the SPD's and got the same results. Finally I ran HWiNFO64 in debug mode three times and sent the results to Mumak (the author of HWiNFO64).
After reviewing the logs his response was "Sorry to say, but those modules have a pretty badly messed up SPD.."
There are a number of other G.Skill Trident RGB owners posting similar issues in the "ROG Crosshair VI overclocking thread" on Overclock.net forum, so I don't think my case is a single aberration.
Here is a link to the screen shots and debug files:
https://1drv.ms/f/s!AmnqYpEo4iX0glqVJgJ1zleEXRsZ
I like the RGB DRAM a lot, but I returned them due to this issue. I am considering whether to order another set, but I am very concerned the same issue would occur.
BTW this for me is not caused by a conflict between G.Skill software and Aura software. I have never installed the G.Skill application.
It's a very dangerous idea! The only purpose of SPD EEPROM is to store SPD data! What the hell did they use SPD EEPROM to control LED? Neither solution will solve the SPD corruption issue, because of the concept itself to use SPD Write commands!
