Originally posted by Meatsweats
View Post
ETA on the next revision?
Originally posted by facehook View PostCheck out CRC of SPD with Thaiphoon Burner software. I bet it is corrupted.
Edit: I was able to get it to work. After resolving both CRC errors it still would not recognize any modules, however after switching slots they 'woke up' and it seems to be working now.Last edited by Meatsweats; 05-31-2017, 08:19 PM.
Originally posted by Meatsweats View PostI tried writing the default SPD through Thiaphoon (had to purchase the full version) but still getting a CRC error on one module.
1) Completely uninstall G.skill RGB Control software and ASUS Aura.
2) Make sure you are not running any hardware diagnostic or sensor monitoring software (hwinfo, aida, cpuz, original software for your mainboard, etc) on the background to prevent the SMBus Controller from deadlocking and SPD data from corrupting.
Hi facehook, I have an NZXT Kraken X52 AIO for my CPU cooling and use the CAM software to monitor temps and manipulate color schemes on the cooler. Do you happen to know if CAM also uses the SMBus Controller?
For context, I have 64 gb of trident z in rainbow default functioning properly and want to avoid blowing up my system. I have held off on installing any G. Skill or Aura software until they iron out all of the bugs.
Are they done even trying to improve the software?Gigabyte Z270 Gaiming 7 (GA-Z270X Gaiming 7) BIOS F4
Intel i5 7600k
Gigabyte GeForce GTX 1070 G1 (GV-N1070G1 GAIMING-8GD)
4x G.Skill Trident Z RGB (DDR4 2400 - PC4 19200)
1TB Samsung 960 EVO
Win10 Home 64bit
Originally posted by jaseph18 View PostJust use AURA my friends
I typically leave my PC on for weeks/months at a time, so it just sits there frozen.Gigabyte Z270 Gaiming 7 (GA-Z270X Gaiming 7) BIOS F4
Intel i5 7600k
1TB Samsung 960 EVO
Win10 Home 64bit
