In the first bank of memory the first bit change from 23 to 0 value . this comport the memory function at only 2133. i try to use thaiphoon burner : function correctly but is impossible buy the program (not know the motive). Exist onother program similar of this only for correct this error?
F4-3600C17-8GTZ with spd crc error
How did the corruption of the SPD happen?
I would recommend to figure that out first and remove the software in question, so that it does not occur again.
There are other apps like RWe that can write to the SPD, if that is allowed on your system. It can sometimes require enabling SPD writes in BIOS. You can check if write protection is in effect with Thaiphoon Burner.
1) RWe Homepage: http://rweverything.com/Team HardwareLUXX | Show off your G.SKILL products!
I not know the ragion of this and i never overclock, but the memory bank haven't problem: i test it alone with mem86. the smbus is unlucked. I think the RWEeverything is not compatible with asrock x370 taichi( amd fch smbus): blank space.where you must selezionate the memory bank .
