I have the following setup:
- ROG Crosshair VIII extreme
- Ryzen 5950x
- G.SKill ram F4-3600C16D-64GVK (2 x 32GB)
At "stock" ram speed (1333Mhz), everything works fine, the system is rock solid and I can use it for days without crashing.
When I enable D.O.C.P to get 1800Mhz, the system seems stable (I can run memtest and other stress tools for hours without error), but after 2 or 3 days of uptime, often at idle or when watching youtube videos, the system suddenly becomes unstable : I cannot launch any new task, I even cannot call the task manager, all running tasks becomes unresponsive one after another. Ultimately, all I can do is a forced shutdown/reboot.
I have no WHEA errors in my event viewer.
I tried adding some voltage to the SOC with no success (up to 1.17V). But I'm pretty sure the issue is not related to the SOC voltage because as I said, all stress tests run smoothly.
I tried to disable D.O.C.P and manually set the RAM timings and voltage (up to 1.5V instead of the 1.45V required for DOCP), but no success.
I also tried to lower the ram frequency to 1600Mhz but the issue remains.
Now I'm lost because I don't even know where my problem comes from. Motherboard ? processor ? RAM ?
Can someone help me on this ?
Thank you.
- Ryzen 5950x
Thank you.
