Faulty f4-3600c16d-16gvkc modules ?
  • Faulty f4-3600c16d-16gvkc modules ?
    Hello all,
    I recently purchased F4-3600C16-16GVKC kit, i.e., on Feb 15, 2021, for my Ryzen 5600x CPU. My system specs include Ryzen 5600x, Gigabyte B550 Aorus PRO-P.
    While playing games, it would crash to desktop. I started getting MEMORY_MANAGEMENT BSODS randomly. This issue persisted on stock settings and XMP BTW.
    I ran MEMTEST86, MEMTEST64, etc., these are all started spewing errors after testing the system for a while (Stock or XMP).
    Later, I switched this memory kit to INTEL 10400F/Gigabyte B460M D3H. The issue stills perists -- games crash after a while, BSODS, etc. Again, I ran the tests (memtest64 etc). these too started showing errors as show in the attached pics.
    I would like your inputs and things I would need to do in this regard.
    Click image for larger version  Name:	20210301_193312.jpg Views:	0 Size:	305.3 KB ID:	166434
    Click image for larger version  Name:	20210301_234505.jpg Views:	0 Size:	210.1 KB ID:	166435
    Click image for larger version  Name:	20210301_192934.jpg Views:	0 Size:	253.7 KB ID:	166433
    Click image for larger version  Name:	20210225_194327.jpg Views:	0 Size:	213.5 KB ID:	166431
    Click image for larger version  Name:	20210225_201623.jpg Views:	0 Size:	126.3 KB ID:	166432
    Have you tried one module at a time to see if one performs differently? If one does, send them in for RMA to the place of purchase and they can send you a replacement kit right away.
      I tested each stick individually, one of the sticks tested individually on the default settings produced MEMORY_MANAGEMENT BSOD, failed Memtest, Prime95, AIDA64 tests, etc.
      I was not able to capture the BSOD on camera, but please have a look at the following images. I am going to the Place of Purchase now and ask them to replace the kit.
        Only one module? Other module worked fine? If so, a new kit should solve the problem.
          Sorry for the late reply. I got another kit from the Place of Purchase and now everything runs fine. No more issues.
          Thanks for your help.
