Is there any recommended solution to water-cool pairs of Neo DRAM sticks?
My mobo will have two sticks on each side of the CPU, in alternating slots (i.e., there will be one empty slot between the two full slots).
I see Alphacool sells D-RAM Modules that look like they fit around each stick using TIM pads, but I suspect they won't fit the Neo packages.
I also see G.Skill and Corsair sell cooling fan kits, but I would prefer to use water.
