I have a Ryzen 7 1700 combo with 4 sticks of G.Skill model Model F4-3000C16D-16GISB. I bought 4 sticks (8GB) for a total of 32gb.
Maximum speed I can get is 2666mhz using the 4 sticks, 2 sticks get me to 3000mhz.
The memory is rated 3000mhz 16-18-18-38,
But I can´t reach that speed, I read that is not possible to reach it on a 4 stick config, whats the next best reachable speed? Care to share you´re configs and maybe OC settings?
Thank you.
- DDR4 3000 (PC4 24000)
- Timing 16-18-18-38
- CAS Latency 16
- Voltage 1.35V
Thank you.
