I looked at the Icy Dock MB990SP-B item. While it appears at t first glance to be a solution, I do not think it will not work in the two lower HDD bays of a Corsair 800D.
Here is a copy of one review that identifies the limitations of this item:
Pros: Can fit two 2.5" drives in a single 3.5" bay
Allows you to install the drives into the adapter w/out using any screws, but...see comments below
Cons: The primary issue with this, and most, 2.5" to 3.5" mounting brackets/adapters is that the mounting holes are not far enough apart to fit in many cases.
On 3.5" hard drives, the mounting holes are ~4" apart along each side.
On 2.5" drives, the mounting holes are ~3.125" apart, and on this (and most) bracket adapters, the mounting holes are only ~2.375" apart.
It won't fit many tool-less, bracket, or rail mounted cases that require the mounting holes to be ~4" apart.
Other Thoughts: The spring action sides are a silly addition. If they provided additional friction inside a standard 3.5" internal bay, so as not to require mounting screws, that would be kind of neat, but it doesn't even come close to that.
The Silverstone SDP08 will serve the same function as this Icy Dock bracket, but will actually fit cases requiring ~4" separation mounting holes.
